Help after rebuild, please - brake pedal stiff but weak breaks
I didn't do any break work during the build, but now the pedal is hard but the breaks are weak. It feels like there is no power assist. I replaced the clutch slave, though. Can it be related? Thanks.
'89 Carrera 4
Old 12-09-2007, 04:13 PM
Are you sure you are getting vacuum to the booster? You might have left the line plugged or disconnected.
regards,
Phil
Old 12-09-2007, 04:37 PM
Thanks, Phil. You jogged my memory that I had to disconnect the ABS pump connector as part of the prep for engine removal - though I don't know why. Forgot to reconnect. Much better, now! Dumb...
'89 Carrera 4
Old 12-09-2007, 07:32 PM
sww914's Avatar
Not dumb, just normal.
Old 12-09-2007, 07:47 PM
efhughes3's Avatar
I think the engine build is the easy part. It is getting all of the fuel injection, electrical and misc junk at the end all done to get the engine started. I forgot a couple of things too. I think with me, it was being anxious to get it in and running.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-11-2007, 07:09 PM
