reassure me, the 1973t cis 7R motor can be built as a 2.0L?
Hi gang,
I have no reference books with me today
but is my memory correct that the spiggot size on the 1973.5 (2.4T motor) with CIS, will allow small cylinders to be used and thus build a 2.0/7r race motor?
I'm pretty confident that my memory is correct, but just need the reassurance since I don't have my books with me at the moment.
thanks
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 12-13-2007, 12:25 PM
304065's Avatar
The measurement is called "Cylinder outer base diameter to crankcase"
2.0 (mislabled as 2.2 in the caption, nice proofing Dempsey!)
92.072-92.159mm (checks with spec book p. 27)
2.2 same as 2.0 (checks to spec book p. 39)
2.4 same as 2.0.
It's only when the 2.7 cylinders appeared that the diameter went to 97.072-97.152mm, or a 5mm change, basically.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-13-2007, 12:38 PM
Thank you John!
needed that reassurance to know I was on the right path!
brant
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 12-13-2007, 12:41 PM
