Timeserts vs Keenserts for exhaust studs?
I pulled an exhaust stud that had already been Helicoiled. I've heard about Timeserts for years but we use Keenserts at work (in standard sizes). After getting a crazy online price for Keenserts ($21.79 ea, yes I asked... each), I found some Timeserts online a bit more reasonable( $1.14 ea after $70 kit which includes 5), and then not 5 minutes later a guy at work found Keenserts for about $2.50 each. The Keenserts look pretty serious, but is it worth buying them over the Timeserts that will be here tomorrow?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 11-13-2007 at 06:16 PM.. |
I would not use keenserts. They are really difficult to remove if you have a problem with them.
70 for the timesert kit, dang I paid way more than that for mine, althought it was the spark plug kit.
Timecerts seem to be what most metric folks prefer, I find them brittle and a little too delicate. Rosan's aka Slimserts are my favorite, but in this application, I am not sure they are available. |
Anyone know what size Timeserts are needed for the exhaust studs and where to get them?
I haven't worked on removing my exhaust yet, but I will be during the Holidays. I'd like to have them on hand when something happens like a broken stud!! Mahalo!
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Installed 12 timecerts on 930 ehaust ports the last time I did a rebuild, worked great with no problems....
munchovie
Is 13 lucky or unlucky ?
I think I bought Timeserts from these guys: http://www.enginetech.com/
The standard length for the 8 x 1.25mm is 12mm, but you could put longer ones in if you wanted.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Mahalo!!
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-19-2007 at 06:58 AM.. |
![]() Is there a reason for the 6mm difference from what 125shifter posted?
I was just stating that 12mm is standard, the 18mm are the longest Timesert and there's room for them in the original hole so I agree 18mm is the best option.
Thank you for clearing that up for me.
