Jakester1168's Avatar
Completely Rebuilt 3.2 - SMOKE!
I just had my 3.2 Carrera engine completely re-built and got it back last week. The entire engine including the lower end was opened....All went well at the initial start up, not a hint of smoke...then yesterday after accumulating just over 400 miles on the engine, I started her up in the morning and a large plume of blue smoke came out! I drove the car for another 4-5 hours yesterday and did not notice any smoke on start ups through out the day...I had driven the car everyday before that for a week straight and had no sign of smoke. I have not yet started her this morning....
Is this smoke a normal part of the break-in process, do I need to be concerned, does the engine need to be opened up again...do 3.2s smoke often?
'88 911 - Stock....sans suspension upgrades
Old 12-25-2007, 04:24 AM
abit off center
cgarr's Avatar
How have you been driving it for break in?
______________________
Craig
G2Performance
Old 12-25-2007, 07:06 AM
Jeff Alton's Avatar
A puff of blue is not uncommon when one starts a 911 motor....
Cheers
www.turn3autosport.com
Old 12-25-2007, 07:30 AM
beepbeep's Avatar
You didn't rebuilt it at Motormeister, did you?
Thank you for your time,
Old 12-25-2007, 07:32 AM
efhughes3's Avatar
Excellent first question when diagnosing a problem with a motor that was "sent out" for rebuild!
What oil are you running? Many run 30W for break-in, which I'd assume could sneak past the rings easier when the engine sits.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-25-2007, 03:31 PM
gigem75's Avatar
Had the car sat for a longer period of time when the start produced the smoke vs when it didn't smoke?
Old 12-26-2007, 08:11 AM
Heck NO! NO MOTORMEISTER...Thank goodness!
....I started it yesterday morning and then again this morning and NO smoke at all this time....
Old 12-26-2007, 08:40 AM
I'll double check the oil type when I get home later today and let you know...Thanks
Old 12-26-2007, 08:41 AM
Cheers
Jeff,
Thats what I've been told...but didn't know if that pertained to a motor with any number of miles on it, or brand new...I started it yesterday morning (no smoke) ran it for 4-5 hours yesterday (no smoke)....started it this morning (no smoke)
Thanks bud.
Old 12-26-2007, 08:45 AM
i worked for the dealer in the 70s and when they started the new 911s on the showroom floor, they waited until there weren't any customers around if possible. they all smoke on startup to some degree.
206 637 4071
Old 12-26-2007, 09:12 AM
beepbeep's Avatar
Well your oil-rings maybe didn't seat yet and some oil got into combustion chamber. Or some oil seeped past valve seals. As long as car doesn't smoke while running, I wouldn't be alarmed.
How much was replaced? New oil-rings? New valve seals? Old jugs? You are still in "break-in" mileage so wait until everything is seated.
Old 12-26-2007, 09:29 AM
MBruns for President
JeremyD's Avatar
and make sure you break it in properly to seat the rings - who did the rebuild?
Old 12-26-2007, 01:32 PM
Yeah....I'm going to wait and put another 100 or so miles on it (500-600 total)...then change the oil, and adjust the valves.
Thanks fellas!
Old 12-26-2007, 05:24 PM
Jeff Alton's Avatar
Don't panic, like I said, from time to time, the 911 motor can fire up with a big puff of blue. This can be totally normal and it can happen all the time, sometimes or once in a blue moon....
What is your oil level like?
Cheers
Old 12-26-2007, 07:20 PM
Some cars do this every morning and some never. I think alot depends on how much oil drains into the bottom of the engine from the tank. Some cars keep the tank pretty full when parked. Others (like my 72) drain almost all the oil into the engine when they sit for a few days. The ones that drain into the sump make alot of smoke when you first start them because oil bathes the back of the pistons and some leaks past the rings. Not really a problem either way.
-Andy
Old 12-26-2007, 08:27 PM
Cheers
Oil level on the stick is at 1/2 to 3/4 up towards the highest mark....
Old 12-27-2007, 06:10 AM
-Andy
Sounds good...Thanks Andy
Super Moderator
cstreit's Avatar
You checked this level when it's RUNNING and HOT right?
As others have said, some smoke on startup is normal and once in a while when the starts align you'll get more; or sometimes none.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-27-2007, 07:26 AM
Absolutely...always check it running and full operating temperature...
So far, last Monday (Christmas Eve) was the one and only time it has smoked...knock on wood...
Old 12-27-2007, 05:03 PM
Just an update....no problems with smoke...hopefully was a one time deal during break-in period...
Now the question is "what brand of oil to use?"..AMSOIL...Castrol Syntec for classic cars (air cooled)?....
I do love this stuff!!
Old 12-29-2007, 01:36 PM
