Completely Rebuilt 3.2 - SMOKE!
I just had my 3.2 Carrera engine completely re-built and got it back last week. The entire engine including the lower end was opened....All went well at the initial start up, not a hint of smoke...then yesterday after accumulating just over 400 miles on the engine, I started her up in the morning and a large plume of blue smoke came out! I drove the car for another 4-5 hours yesterday and did not notice any smoke on start ups through out the day...I had driven the car everyday before that for a week straight and had no sign of smoke. I have not yet started her this morning....
Is this smoke a normal part of the break-in process, do I need to be concerned, does the engine need to be opened up again...do 3.2s smoke often?
'88 911 - Stock....sans suspension upgrades Last edited by Jakester1168; 12-25-2007 at 04:28 AM.. |
abit off center
How have you been driving it for break in?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
A puff of blue is not uncommon when one starts a 911 motor....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
You didn't rebuilt it at Motormeister, did you?
Thank you for your time, |
Excellent first question when diagnosing a problem with a motor that was "sent out" for rebuild!
What oil are you running? Many run 30W for break-in, which I'd assume could sneak past the rings easier when the engine sits.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Had the car sat for a longer period of time when the start produced the smoke vs when it didn't smoke?
Heck NO! NO MOTORMEISTER...Thank goodness!
....I started it yesterday morning and then again this morning and NO smoke at all this time....
'88 911 - Stock....sans suspension upgrades |
I'll double check the oil type when I get home later today and let you know...Thanks
Thats what I've been told...but didn't know if that pertained to a motor with any number of miles on it, or brand new...I started it yesterday morning (no smoke) ran it for 4-5 hours yesterday (no smoke)....started it this morning (no smoke) Thanks bud.
i worked for the dealer in the 70s and when they started the new 911s on the showroom floor, they waited until there weren't any customers around if possible. they all smoke on startup to some degree.
Well your oil-rings maybe didn't seat yet and some oil got into combustion chamber. Or some oil seeped past valve seals. As long as car doesn't smoke while running, I wouldn't be alarmed.
How much was replaced? New oil-rings? New valve seals? Old jugs? You are still in "break-in" mileage so wait until everything is seated.
MBruns for President
and make sure you break it in properly to seat the rings - who did the rebuild?
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thanks fellas!
Don't panic, like I said, from time to time, the 911 motor can fire up with a big puff of blue. This can be totally normal and it can happen all the time, sometimes or once in a blue moon....
What is your oil level like? Cheers
Some cars do this every morning and some never. I think alot depends on how much oil drains into the bottom of the engine from the tank. Some cars keep the tank pretty full when parked. Others (like my 72) drain almost all the oil into the engine when they sit for a few days. The ones that drain into the sump make alot of smoke when you first start them because oil bathes the back of the pistons and some leaks past the rings. Not really a problem either way.
-Andy
72 Carrera RS replica, Spec 911 racer |
Oil level on the stick is at 1/2 to 3/4 up towards the highest mark....
Super Moderator
As others have said, some smoke on startup is normal and once in a while when the starts align you'll get more; or sometimes none.
So far, last Monday (Christmas Eve) was the one and only time it has smoked...knock on wood... Thanks
Just an update....no problems with smoke...hopefully was a one time deal during break-in period...
Now the question is "what brand of oil to use?"..AMSOIL...Castrol Syntec for classic cars (air cooled)?.... I do love this stuff!!
