Dual pipe exhaust for 2.4S?
Hi all,
in the Porsche 911 Performance Handbook (Bruce Anderson) it is mentioned that the power of a 2.4S can be lifted to 210 BHP when using a dual pipe sports exhaust.
- which exhaust is this? I have bought an exhaust with outlets both left and right, but I am wondering if the book actually refers to the exhaust with the two parallel pipes exiting in the middle of the exhaust (is this the 'pea shooter'?)
- Has anybody tried this?
Thanks!
Dennis
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 12-23-2007, 01:07 PM
I don't think that number you quote is in the book. His book does show that you can gain about 10 HP with a sport muffler. The dual outlet sport muffler is usually considered to be the "pea shooter" that you reference above. I believe that most dual outlet mufflers will give you this boost.
-Andy
Old 12-23-2007, 01:38 PM
Try not, Do or Do not
Henry Schmidt's Avatar
This one is from M&K
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-24-2007, 06:42 AM
Is it true this type of exhaust works better with carbs than MFI?
Regards
Mike
RS #1551 (Sold)
67S
Old 12-27-2007, 09:55 AM
Andy, check the graph on page 141. Pretty close to 210
Dennis
Old 12-30-2007, 09:05 AM
Dennis,
I have the older version of the book so my graph is on page 133. It shows a 10 HP increase at 5500 RPM. The stock curve stops there in the graph at 190 HP. Since the peak HP of the 2.4s motor is around 6200 RPM, this graph shows a stock 2.4 with about 200 HP. The improvement with the muffler is 10HP.
-Andy
Old 12-30-2007, 10:37 AM
