exhaust port pitting
Hello all: please review this picture of a 76 930 turbo head. I just finished cleaning and blasting lightly with walnut shells. My concern is the deep pitting that is in the exhaust port –
1. Anyone else have this problem? 2. Anyone know what could cause the pitting of the aluminum? 3. Should I get the high speed grinder after it and smooth it out? 4. Should I open up the port size by removing some of the meat where the indention stops ( open up the inner diameter to match port diameter ) ? Thanks! Munchovie.
Evolved
I do not have long term experience with P-car heads, but I would assume that the pitting is probably normal (high mileage, air cooled/alum. head).
Is it just the ONE port or all exhaust ports? Unless you are building a race car engine, any porting will be, at best, minimally effective ... and at worst, detrimental. Not a 'do it yourself job' unless you know what you are doing. JMO
Don't fear the reaper. Last edited by Mo_Gearhead; 11-26-2007 at 05:36 AM.. |
maybe can be caused buy the walnut blasting that you use.
You can take the grinder and smooth it. I use the air grinder with a metal stick with sand paper. I use a sanding belt that I cut in 1 inch strips. I always buy some grits from the coarse one to me smoth one. I use first 80, 120, 180. Because is the exhauts port, you can polish to a mirror finish, this will help to avoid the carbon build up.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! |
Munch,
don't know how I missed this one. If you have the time and patience take a look at this thread by Kevin at UMW regarding DIY head porting for our turbos: http://forums.rennlist.com/rennforums/showthread.php?t=192483&highlight=head+porting JP
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
I'm surprised the walnut shells would eat into the aluminum. More likely, it's the casting marks.
Here's a pic of one of my intakes after opening it up for a 3.2 intake.
I think it's corrosion caused by moisture in the carbon buildup.
Not QUITE as bad as this but you can see what water will do to a head.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
+1 with John Cramer, it does appear to be from corrosion build up and moisture creating almost an acid and it started to "eat" the surface metal. Good luck!!
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
