Head Stud Troubles
Im in the process of fitting my aftermarket head stud kit and I seem to be having trouble getting the thread lock to harden. Ive left them overnight then tested them to make sure they have stuck and only 1 out of the 8 I have just tried stood up to a resonable amount of force most of them undo like there in nothing on them. Where can I be going wrong?
BTW im using blue permatec stud lock that came with the kit. Steve
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
did you degrease the threaded holes with brake-kleen and blow them dry?
Hi John yes I degreased them with paint thinners. Can the temp affect the thread lock?
Paint thinner doesn't evaporate very well. I prefere Acetone or Laquer thinner. There are also primer products for Locktite (they smell like Acetone).
-Andy
72 Carrera RS replica, Spec 911 racer |
Banned
If you used any oil based paint thinner (like mineral spirits) to clean your stud bosses then that is your problem . . . as per the previous reply, you must use a cleaner that leaves no residue. The air temp should not affect the thread locker in the manner you describe . . .
Ronnie |
Stranger on the Internet
I would concur with eagledriver and JW. I use either acetone or methyl ethyl ketone for prep cleaning. Also, blue Loctite is not the end-all. The special red stuff is the cats a$$.
Pat
Patrick E. Keefe 78 SC |
I would have suggested the Loctite green to be used for studs.
609 I think is the number....permanent...needs heat to take them out. Bob
Bob Hutson |
I used automotive cellulose paint thinner which is solvent not oil based. I will get some acetone from work and re-do them with red locktite.
If they are not a tight fit that could cause trouble. Loctite thread lock is anerobic meaning it cures in the absence of air. You will notice that it does not cure when left on an open surface.
Art '75 911 US Carrera #390 '74 MGB, AH 3000 BN7 V8, '65 Mustang Fastback, 66 bronco U13 |
