degreeoff1's Avatar
Jet and Choke sizes doable on my new engine?
Hello and thanks for your replies in advance.
I am looking at buying a set of carbs that have the following venturi's and jets. Will these work well for my 2.7 with 9.8:1 compression ported to 38/36and GE 40 cams?
AV's: 4.5
Vens: 36
Mains: 145
Idles: 55
Idle airs: 130
Airs: 190
Tubes: F11
FBCV's: 50
Fittings: HB
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 02-13-2008, 08:22 AM
I think those will be close. The venturi size is perfect. You might need to open up the mains to 150 or 155. I don't have alot of experience however so expert advise might help. LM1 or a trip to the dyno will dial it in.
-Andy
Old 02-13-2008, 09:07 PM
