Nitrometano's Avatar
Wrist Pin Bushing
Hello guys,
I have a question about the wrist pin bushing (rod small end bushing) that Pelican's sells. The part number is 901-103-131-01-M41 and his brand is Glyco.
I know that the aftermarket wrist pin bushings like the solid ones that the machine shops do, nees to be reamed or bored to the factory specs size. This ones, the Glyco that I mentioned, need to be reamed or bore to factory specs or is just an press in and all is done?
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 01-28-2008, 11:47 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I have never heard of a bushing , for any purpose, that once pressed into a hole does NOT need reaming.
If you think about it...the bushing is compressed into the hole on the outside...so the inside has to get smaller!
When working with the wrist pin bushings...watch for holes lining up for oiling.
Pressing in the bushing is easy...I have used presses and even a vice on one occasion.
However...make sure the bushing goes in straight...then ream to size...then de-burr the edges.
Good luck
Bob
Bob Hutson
Old 01-29-2008, 06:16 AM
do you make your own reaming?
1972 911T
Old 01-29-2008, 11:59 AM
I thought I'd use an existing thread for this question as it do cover basically the same thing.
I got this kind of replacement bushings for my 2,0L T engine. (The one to the left)
Where is the "joint" supposed to be when installed into the rod?
Old 11-29-2009, 02:15 PM
Puny Bird
Mark Henry's Avatar
TDC and BDC would have the most load so I've always aimed for the seam to be to the side so it's mid stroke.
Most of the bushings I've done I had to drill the oil holes after installation...but I'm a bug guy.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 11-29-2009, 03:46 PM
Ok. That was how I was thinking too.
Do you pre-drill the oilholes or drill them after they have intalled the bushings in the rods?
Old 11-29-2009, 10:03 PM
installation first, then drill it.
1972 911T
Old 11-30-2009, 05:05 PM
