3.2 Carrera EFI alternative ???
Hello guys,
As I need to buy : DME,DME harness,DME relay and AFM for my engine (3.2 Euro)
I wonder if there is available an alternative engine EFI system that I can use in the place of the stock Motronic?
Also one more question for the Motronic guys : The US and Euro DME harnesses are the same ?
TIA,
Jim
Old 03-03-2008, 02:50 PM
I would rather be driving
jpnovak's Avatar
Try a megasquirt. The only issue is that you will need to mount a new trigger wheel to the crank pulley. MS will not decode the flywheel teeth pattern. It will work based upon a MAP sensor that pulls signal from a vacuum port on the manifold. All you will need is the intake, throttle body injectors and fuel rails. Its a DIY type of system and most shops will not be familiar with it. This could be a plus or minus depending on how you approach car work.
Old 03-03-2008, 02:57 PM
