3.2 removing blower motor duct ?
In the picture below (courtesy of trown_hammer) is a 3.2 engine with the heater duct replaced with a steel piece.Is this a SC,2.7 or older or I have to fabricate one from scratch ???
Thanks! ![]()
Schleprock
Shawn's was fabricated but you can get one from an earlier engine that's got only a small snorkel it instead of the big wide tube that the 3.2 typically has.
I bought a used 3.2 piece and cut off the wide tube. Then I cut a piece of sheetmetal to cap the opening.
Kevin L '86 Carrera "Larry" |
Thanks for the info Kevin!
