Optimum a/f's for 3.5 race motor
What is the optimum a/f for a 3.5 race motor running 46mm webers, ge 60 cams, electromotive hpv-1, 1 3/4" hearders and sport muffler. The dyno is showing 13.9-14.1 from 5,000-6500.
A/F ratio's
for safe peak power/torque 13.0 - 13.1 is what we shoot for on a hi compression non turbo, be sure the sensor is reasonably fresh so you get an accurate rate and make sure that its not pulling air before the sensor for a false reading.
Mike Bruns JBRacing
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Sorry to hijack, Mike I sent you an email through JBRacing....
I am showing 12.8 on my 3.4 where we made max power. Same reading on both the LC-1's I have mounted in the car and the sensor the shop had in the tailpipe. how much is this affected by intake temp, or is it at all?? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
