gumba's Avatar
Optimum a/f's for 3.5 race motor
What is the optimum a/f for a 3.5 race motor running 46mm webers, ge 60 cams, electromotive hpv-1, 1 3/4" hearders and sport muffler. The dyno is showing 13.9-14.1 from 5,000-6500.
Old 04-06-2008, 08:51 AM
A/F ratio's
for safe peak power/torque 13.0 - 13.1 is what we shoot for on a hi compression non turbo, be sure the sensor is reasonably fresh so you get an accurate rate and make sure that its not pulling air before the sensor for a false reading.
Mike Bruns JBRacing
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 04-06-2008, 12:20 PM
Jeff Alton's Avatar
Sorry to hijack, Mike I sent you an email through JBRacing....
I am showing 12.8 on my 3.4 where we made max power. Same reading on both the LC-1's I have mounted in the car and the sensor the shop had in the tailpipe.
how much is this affected by intake temp, or is it at all??
Cheers
www.turn3autosport.com
Old 04-17-2008, 10:18 PM
