hi to all need help i was extracting broken studs on my motor when i broke the e-z out stud extractor in stud ,too low to weld a bolt or anything else ,anyone know is there a drill bit , carbide tip or something stong enought to eat up the extractor..thanks guys ....Angel
pca 30 year member,1977 porsche turbo body targa 56 vw ragtop oval 01 harley sportster 18 Chevy Colorado diesel BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL |
abit off center
Try a small carbide ball die grinder, had to use them on taps before.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Irrationally exuberant
As my friend Mark DeYoung told me once:
"An EZ-out is an tool for replacing a difficult to drill out bolt with an impossible to drill out EZ-out" -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
3 restos WIP = psycho
EDM time...
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
+1 on the carbide drill bit, but you have to have a steady hand with the smaller bits our they snap
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
What size E-Z out bit broke? If you have a good Dremel, or similar tool, you might be able to get the broken bit out with repeated use of some of the very small carbide, or diamond bits. I have seen too many of the extractors break(square type more often) then it really is a pain, as you are now finding out. If you can get the broken tip out of the broken bolt/stud, invest in a quality set of left-handed drill bits. I have yet to be defeated by a flush or below surface broken stud/bolt, when removing them with the proper left-handed drill bit. I personally use a DeWalt 18V 1/2" Hammer Drill, set on Low Speed, with the torque ring set for the hammer. The hammer action really helps get the broken stud/bolt quickly. I do not believe that I even own any of the E-Z out, or other similar extractors, because I have seen them fail too many times.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Thanks to all who responded this be will next weeks project ,hopefully patience and time will help .........thanks for all your suggestions
Air Medal or two
with stubborn bolts/ studs HEAT is your friend, and not a Lil propane torch.....propane and oxy is great and safe (safer then acetylene). I swear they see that coming at them and they leap out !!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Stranger on the Internet
The small carbide files spoken of here are common dental burrs, which you can get at a dental suppluy house. Chuck it up in a Dremel.
Patrick E. Keefe 78 SC |
Worst case scenario is to take it to a machine shop and have them drill it out with a carbide drill. I have broken taps before and a carbide drill will go right through it.
Since EZ-outs (and taps) are brittle, I've used a hammer and a center punch to break them up where they've snapped in thick flat plate. I'd be very careful not to booger anything else up trying this in your situation. Are you installing inserts anyway?
Tim K |
