angelny911's Avatar
Red face removing broken ez-out
hi to all need help i was extracting broken studs on my motor when i broke the e-z out stud extractor in stud ,too low to weld a bolt or anything else ,anyone know is there a drill bit , carbide tip or something stong enought to eat up the extractor..thanks guys ....Angel
pca 30 year member,1977 porsche turbo body targa
56 vw ragtop oval
01 harley sportster
18 Chevy Colorado diesel
BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL
Old 02-18-2008, 08:28 AM
abit off center
cgarr's Avatar
Try a small carbide ball die grinder, had to use them on taps before.
______________________
Craig
G2Performance
Old 02-18-2008, 08:30 AM
you can use a Metal Disintegrator
http://www.electroarc.com/
Old 02-22-2008, 12:00 PM
Irrationally exuberant
ChrisBennet's Avatar
As my friend Mark DeYoung told me once:
"An EZ-out is an tool for replacing a difficult to drill out bolt with an impossible to drill out EZ-out"
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-22-2008, 12:05 PM
3 restos WIP = psycho
kenikh's Avatar
EDM time...
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-22-2008, 12:08 PM
930gt-40r's Avatar
+1 on the carbide drill bit, but you have to have a steady hand with the smaller bits our they snap
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-22-2008, 05:04 PM
3.2 CAB's Avatar
What size E-Z out bit broke? If you have a good Dremel, or similar tool, you might be able to get the broken bit out with repeated use of some of the very small carbide, or diamond bits. I have seen too many of the extractors break(square type more often) then it really is a pain, as you are now finding out. If you can get the broken tip out of the broken bolt/stud, invest in a quality set of left-handed drill bits. I have yet to be defeated by a flush or below surface broken stud/bolt, when removing them with the proper left-handed drill bit. I personally use a DeWalt 18V 1/2" Hammer Drill, set on Low Speed, with the torque ring set for the hammer. The hammer action really helps get the broken stud/bolt quickly. I do not believe that I even own any of the E-Z out, or other similar extractors, because I have seen them fail too many times.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 02-23-2008, 06:32 AM
angelny911's Avatar
Thumbs up e-z out
Thanks to all who responded this be will next weeks project ,hopefully patience and time will help .........thanks for all your suggestions
56 vw ragtop oval
01 harley sportster
Old 02-23-2008, 07:25 AM
Air Medal or two
afterburn 549's Avatar
with stubborn bolts/ studs HEAT is your friend, and not a Lil propane torch.....propane and oxy is great and safe (safer then acetylene). I swear they see that coming at them and they leap out !!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-23-2008, 05:14 PM
Stranger on the Internet
patkeefe's Avatar
The small carbide files spoken of here are common dental burrs, which you can get at a dental suppluy house. Chuck it up in a Dremel.
Patrick E. Keefe
78 SC
Old 02-23-2008, 06:24 PM
Worst case scenario is to take it to a machine shop and have them drill it out with a carbide drill. I have broken taps before and a carbide drill will go right through it.
Old 02-29-2008, 08:56 AM
Tim K's Avatar
Since EZ-outs (and taps) are brittle, I've used a hammer and a center punch to break them up where they've snapped in thick flat plate. I'd be very careful not to booger anything else up trying this in your situation. Are you installing inserts anyway?
Tim K
Old 02-29-2008, 09:13 AM
