JW Apostate
trekkor's Avatar
2.7 cam options
911/92 motor.
Will have Webers.
For track.
I want max power.
Also, will my mech advance dizzy from my 2.0 fit in place of the vac advanced one?
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 03-02-2008, 10:24 PM
KT,
Cam decisions get based on vehicle gearing and weight. Remember, the more HP you want, the narrower the torque & HP range will be so that affects how difficult the car will be to drive (race).
The 2.7 uses a distributor with a 30mm shaft; your 2.0 has a 27mm one so that won't work. Your 2.7 distributor can be modified for centrifugal-only advance.
Of course, if you use twin-ignition, you'll use a much better unit anyway,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-02-2008, 11:35 PM
JW Apostate
trekkor's Avatar
Thanks,
I am used to a 5000-7300 operating range with my MSX geared 901 box.
With a cam change am I limited do to valve to piston clearances?
KT
'01 Boxster
Old 03-02-2008, 11:41 PM
JW Apostate
trekkor's Avatar
Tell me more about the dizzy mod.
Sounds interesting.
KT
'01 Boxster
Old 03-02-2008, 11:43 PM
To be honest with you, a 5K to 7300 RPM power range is a street engine,...
Thats what "S" cams do in a 2.0 to 2.7 litre motor. If you need more HP (and thusly a higher RPM range with a narrower spread of HP), you will need a proper close-ratio gearset to keep the engine inside its torque & power range.
I cannot tell you what cams will work in your engine without knowing precisely whats inside and what configuration/specifications you currently have.
If you want HP you will need compression, headwork, to get more revs. That requires different pistons, more cam, and a whole host of mechanical upgrades and modifications to the oiling system to ensure that the engine will be reliable at those engine speeds.
Twin-ignition is a must for any high-power 911 race engine and that requires a special distributor for that. You can contact me directly for more information on that.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-02-2008, 11:53 PM
JW Apostate
trekkor's Avatar
Will my "S" cams from my 2.0 motor 'fit'?
My close ratio gear box is fantastic!
KT
'01 Boxster
Old 03-03-2008, 12:01 AM
JW Apostate
trekkor's Avatar
Also, why is there such a big difference in hp between the various 2.7 motors?
KT
'01 Boxster
Old 03-03-2008, 12:18 AM
KT,
I ran a 2.7 RS spec motor in my Toyo cup car for several years. I had a 915 with 7:31RP in the car. I started out with a Solex grind cam profile and then rebuilt the motor with an "S" cam profile. I got more peak power out of the S cams but I would definitely say the Solex cams were better both on the track and street. Lap times were identical.
-Andy
Old 03-03-2008, 08:42 AM
JW Apostate
trekkor's Avatar
Would a 175hp target be reasonable?
"S" cams with Webers...
KT
'01 Boxster
Old 03-03-2008, 08:58 AM
KT,
Your "S" cams will fit the 2.7 but you need to have the right pistons (not CIS ones).
The HP differences between all the 2.7 engines is due to variations in port diameters, camshafts, intake systems, and exhaust systems.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-03-2008, 09:09 AM
JW Apostate
trekkor's Avatar
I guess I'll just run it 'as-is'.
I do not want to tear the motor down unless there is another cam option that will allow me to keep the stock pistons.
KT
'01 Boxster
Old 03-03-2008, 09:19 AM
The biggest cams that work with the CIS pistons are 964-grind ones.
You would need to have some 3-bearing cams reground or made since the newer 4-bearing (SC-3.6) cams will not work in your existing 3-bearing cam housings.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 03-03-2008, 09:49 AM
I would rather be driving
jpnovak's Avatar
Steve, Can you confirm that a 964 cam will clear a stock 2.7 CIS piston? I was under the impression from previously posted information that the exhaust duration would cause the exhaust valve to contact the piston on the down stroke (chasing effect). I don't recall anyone stating for sure this would/would not work.
Old 03-03-2008, 10:45 AM
JW Apostate
trekkor's Avatar
Thanks for the good replies.
KT
'01 Boxster
Old 03-03-2008, 10:49 AM
Ray_G's Avatar
I would be interested to know what cams will work with the stock cis pistons as well. I am going to be putting my 2.7 together soon and I am still up in the air about the cams. I have also been told the 964 can cause clearance problems.
76 911S Targa
An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage!
Old 03-03-2008, 07:26 PM
