1972_911T's Avatar
DC20 Cams With Tbitz MS Setup
Im fitting DC20 cams in my current rebuild 3.0 engine, the engine will be run on common plenum Tbits Efi conversion, am I going to have idle issues with the DC20's on a common plenum? I originally bought these cams as I was intending to run ITB's
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 03-08-2008, 04:31 AM
Wer bremst verliert
JohnJL's Avatar
I ran a DR20 cam with a Carrera alu intake on EFI. I got a broad, fat torque curve though overall peak output wasnt what I had been hoping for.
Car was tracked exclusively. I ran 26lb injectors. The heads needed to be modified slightly to fit the injector angles.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-08-2008, 04:56 AM
Jeff Alton's Avatar
That cam is designed for a common plenum intake.
Cheers
www.turn3autosport.com
Old 03-08-2008, 07:32 AM
