DC20 Cams With Tbitz MS Setup
Im fitting DC20 cams in my current rebuild 3.0 engine, the engine will be run on common plenum Tbits Efi conversion, am I going to have idle issues with the DC20's on a common plenum? I originally bought these cams as I was intending to run ITB's
1972 911t RS Styled G50 conversion underway 1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695 |
Wer bremst verliert
I ran a DR20 cam with a Carrera alu intake on EFI. I got a broad, fat torque curve though overall peak output wasnt what I had been hoping for.
Car was tracked exclusively. I ran 26lb injectors. The heads needed to be modified slightly to fit the injector angles.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
That cam is designed for a common plenum intake.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
