-   -   The Begining (http://forums.pelicanparts.com/911-engine-rebuilding-forum/397314-begining.html)
peppy 03-09-2008 08:32 AM
The Begining
Starting my rebuild.
1988 Targa
98K miles
oil consumption 1qt. per 2500 miles
I have 2 broken head studs that I found, and only pulled one valve cover.
I am starting this thread so that I will get all of the criticism of what I am doing wrong.
I have a tendency to cut corners, because I am cheap.
http://forums.pelicanparts.com/uploa...1205076318.jpg
The drop.
http://forums.pelicanparts.com/uploa...1205076349.jpg
The tool.
http://forums.pelicanparts.com/uploa...1205076375.jpg
My help.
http://forums.pelicanparts.com/uploa...1205076396.jpg
Myself.
http://forums.pelicanparts.com/uploa...1205076421.jpg
peppy 03-10-2008 03:15 PM
WOW! 70 views and not one smart alek comment about me being cheap.
Did I post this in the wrong place.
cgarr 03-10-2008 04:15 PM
What corners are you cutting?
peppy 03-10-2008 04:42 PM
I don't know just yet. I guess it depends on what I find when I get into the engine.
cgarr 03-10-2008 06:46 PM
That does not seem to be a lot of miles, Thinking maybe go with just a top and cams or no upgrades at all? How was the pressure?
peppy 03-10-2008 06:57 PM
Graig I never checked compression. I am thinking about doing a cold leak down, I really do not think it will give me a definitive answer about rings.
cgarr 03-10-2008 06:59 PM
What about oil pressure?
peppy 03-10-2008 07:05 PM
Oil pressure was fine 1 bar per 1k RPM.
The car has been sitting for the better part of 3 years. I have only driven it 700 miles. I think this had something to do with the head studs breaking.
MatthewBrum 03-12-2008 12:17 PM
good luck on the rebuild, I'm sure you will be able to find plenty of ways to be cheap without cutting corners. This board is full of practical and affordable ways to get the job done right :)
peppy 03-14-2008 08:13 AM
Started the disassembly
I start yesterday and here are a few pics.
How do you tell if the G-50 update has been done?
I cut this wire. What is this?
http://forums.pelicanparts.com/uploa...1205507415.jpg
http://forums.pelicanparts.com/uploa...1205507471.jpg
http://forums.pelicanparts.com/uploa...1205507492.jpg
http://forums.pelicanparts.com/uploa...1205507538.jpg
http://forums.pelicanparts.com/uploa...1205507569.jpg
charleskieffner 03-14-2008 08:31 AM
known 3.2 fix its........
rod bolts
valve guides
valves
springs
crap fuel line change to aircraft fuel line
updatum clutchem
updatum G-50 since yers is a 88 may already have parts from p.o.
8th journal seal
theres a few for starters.
the only cheap in the equation is yer labor.
the wire if im correct is cylinder head temp sensor
purplehaze 03-14-2008 01:17 PM
Looks like you cut the wire to the cylinder head temp sensor, about $75.
I DO like your molded wooden engine cradle. Clever!
Glenn
peppy 03-15-2008 08:54 AM
Looks like the update has not been done on the clutch.
The shaft came out easy, I did spray it with PB blaster.
Head sensor will probably be replaced, or I could just solder the wire back together.
The parts list is getting big!
peppy 03-20-2008 02:50 PM
More Progress
All of the exhaust bolts were rusted.
http://forums.pelicanparts.com/uploa...1206049315.jpg
This is the easiest way to get them off, cutting torch.
http://forums.pelicanparts.com/uploa...1206049328.jpg
http://forums.pelicanparts.com/uploa...1206049427.jpg
Broke two bolts on the shroud.
http://forums.pelicanparts.com/uploa...1206049542.jpg
http://forums.pelicanparts.com/uploa...1206049591.jpg
Alternator was the hardest thing to remove so far.
http://forums.pelicanparts.com/uploa...1206049633.jpg
This are going pretty well so far, but I am just at the start.
OldTee 03-22-2008 07:48 AM
My first Porsche engine o/h was a 87 last year. Came out OK. Have lots of plastic bags (of all sizes) available and label everything. Take lots of pictures. Don't mix up cylinder stuff. Keep it separate. Replace the head temp lead. They are impossible to replace one the engine is installed without a lot of work. Don't skimp on parts. Have alternator overhauled while it is out. Starter too. Take your time. Have fun.
peppy 03-22-2008 01:28 PM
OldTee I plan on doing the alternator, but I may skip the starter. I can always push start it.
I finally got it on an engine stand.
http://forums.pelicanparts.com/uploa...1206217575.jpg
http://forums.pelicanparts.com/uploa...1206217586.jpg
Is there a trick to getting to the nuts on the heat exchangers? I know the barrel nuts use a long hex head.
rlane 03-22-2008 04:00 PM
The nuts requiure various combinations of 12 or 13 mm flex sockets (depends on whether they are original or replaced) especially helped by a flex extension or a 6" wobble extension. There is a special tool for the barrel nuts but pick up a set of Harbor Freights inexpensive "ball end" Allen wrenchs and the (I think) 8 mm fits and allows you to get in to the sometimes off angle barrel (off angle in relation to the access hole in the HE. Some folks bend a 12 or 13 long box wrench for accessing the nuts as well
peppy 03-22-2008 07:36 PM
Thanks Richard.
sww914 03-22-2008 11:45 PM
I'm cheap too. Some guys pull out all the stops and do everything on their 911 build in the most optimal fashion possible. That's the right way to do it, but I usually can't afford either the time or the money, maybe both. If everything is absolutely perfect it should last longer, but I like a bit of adventure too. :-)
peppy 03-24-2008 01:49 PM
http://forums.pelicanparts.com/uploa...1206391225.jpg
http://forums.pelicanparts.com/uploa...1206391239.jpg
http://forums.pelicanparts.com/uploa...1206391287.jpg
http://forums.pelicanparts.com/uploa...1206391300.jpg
I found what looks like a piece of coat hanger with a rubbery substance stuck behind the oil cooler.
All went well today except for the rocker bushings. They were very rusty, and the small hex head stripped. I ended up drilling the large hex head side until it released.
