sand cast AL case full rebuild
I'm in the teardown phase of a full rebuild of my sandcast 67S engine.
I'd like to know what modifications are recommended in light of 40
years of working knowledge about these engines. I'm going for stock
appearance but don't mind mods where it makes sense.
The things I've settled on so far:
- bigger oil pump from 3 litre engine
- 930 tensioners w/safety collars
- cast iron rocker arms w/bushings
I'm considering getting hotter cams from camgrinder, depends on whether
my camshaft is within spec or not. Also a better distributor from 123ignition.nl
All advice appreciated.
andy
Old 03-31-2008, 05:22 PM
3 restos WIP = psycho
kenikh's Avatar
The '67S charm is the cam. Mess with that and you may alter its appeal. That said, camgrinder made me a set of DC44s on 102 lobe centers. On paper, the are amazing, but won't be running until the end of summer.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-31-2008, 10:35 PM
I just got Wayne's book. Brilliant. Lists all the things I need to do to increase
the reliability of the engine. Looks like the 930 tensioners I bought for rebuilding
were actually 901 tensioners like the ones I already have. I guess the safety
collars were worth the $10 I paid.
The experienced guy who is helping me rebuild my engine got me to remove the
rocker arms prior to removing the camshafts, I can't work out why after reading
Wayne's book. Wayne lists the rocker arm removal as one of the final steps.
Any ideas?
andy
Old 04-01-2008, 04:44 PM
Andy
The cams will not come out of the cam towers unless you remove the rockers first.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 04-01-2008, 07:13 PM
304065's Avatar
Teardown:
Teardown of 1966 901/05 Engine
Tumble-Polished Case:
Aluminum 901/05 Engine Case Tumble-Polished: Perfection Defined
Rods:
Bored? You'll think about stroking when you see these rods.
Pistons:
Jugs and Slugs: Confessions of a JE Piston owner
Heads:
Bouffant hairdos, Miranda, Grace Slick and THESE HEADS
Carbs:
Carburatori Bellissimo! Restored Weber IDA3C
Oil Cooler:
Oil Cooler rebuilt by Pacific Oil Cooler
Measuring things:
Measurement, Instruments and Metrology
Sorting out hardware:
REAL Cadmium Plating of Engine Hardware
Assembling Bottom end:
Assembling 1966 901/05 Engine- Phase I- Bottom End
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-02-2008, 08:06 AM
Hi John, none of those links work.
andy
Old 04-07-2008, 06:05 PM
304065's Avatar
Linko el-fixo.
'81 R65
Old 04-09-2008, 06:47 AM
