What are these ususual 2.7 Heads?
I came across these unusual 2.7 heads in my large stock of 911 heads, They stand out as being unusual because they do not have either the CIS relief in the intake port nor an MFI bung. They appear to be carb heads and have an air injection bung in the exhaust port. The port and valve sizes are the same as the 2.7 Euro Carrera
Specs: Exhaust port - 35mm Intake port - 36mm Exhaust valve - 40mm Intake vale - 46mm Casting stamp - 911.104.342.2R Can anyone identify these? ![]() ![]() ![]()
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
abit off center
I have the same setting here right now, if you look closely you should see where the CIS relief is welded up, perhaps from the factory? I didn't notice it until the intakes were opened up to 37mm
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Craig
Thanks...I'll take a closer look.
Thread Tools | |
Rate This Thread | |
