Race gas tuning
I'm new to race gas.
I took the car with it's freshly rebuilt motor to a chassis dyno for some break in. It ran pretty strong for right out of the box. I was conservative with timing....25-28 deg total and it was blowing black smoke. Did a few pulls after 30-40 minutes of run time. The sheet below shows AF ratio curve on the bottom line......the printing is kinda small. I'm running 135 mains but have a set of 130s that I'm thinkin' about swapping in. Is that too much of a jump? The other pulls show a richer AF ratio 11.9-13.0 ....
JPIII Early Boxster Last edited by J P Stein; 04-06-2008 at 08:11 AM.. |
Lotta lookers but no help.
Is the AF ratio OK? I know the graph is hard to see, but that's what I got.
JPIII Early Boxster |
Hi JP,
I really cannot tell you anything definitive due to lack of resolution on that print-out. When we dydno a motor, the software is configured to print both a decending chart in 200 RPM increments as well as print a graph with the same resolution so one can clearly see the AFR's at all RPM points. They simply need to reconfigure their Mustang computer's software as I know it will do just that,... Once thats done, they should be able to print that again with improved resolution, assuming that they saved the data.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
