Cam Bar Tool question
Am rebuilding a 1986 930. I haven't used cam bar before to remove the cam nut. My other car had the 46mm nut-this has the 19mm nut. Since the sprocket holes are all spaced differently, will the cam bar only fit on the sprocket in one orientation, or will it fit onto any three holes?
Old 04-05-2008, 11:25 PM
peppy's Avatar
I just removed mine, and I either got lucky or it will fit in any three holes.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 04-06-2008, 07:14 AM
Banned
. . . and if you use a pneumatic impact gun you don't need to use the cam bar/sprocket holder for removal of the 19mms - the impact spins them right off with no effort or problems!
Ronnie
Old 04-06-2008, 06:39 PM
peppy's Avatar
Ronnie don't you still need the tool to tighten them back?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 04-07-2008, 02:14 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The late style pinned cam sprocket counterholding tool fits any of the holes on the cam sprocket.
Kevin L
'86 Carrera "Larry"
Old 04-08-2008, 11:58 AM
Less brakes, more gas!
euro911sc's Avatar
Ronnie
If you are going to use new chains this is fast and fine... else use your hands and the tool to prevent any chain damage.
regardless... you need the tool to get it all back together as stated by Peppy.
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-08-2008, 12:26 PM
peppy's Avatar
I just removed my right side cam yesterday, and the cam tool would not fit in some of the holes. I did not spend a lot of time looking at why, but it fit if I rotated the tool 180 degrees.
I think that the washer behind the 19mm bolt or the sprocket behind the pulley blocks the holes a bit.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 04-11-2008, 03:12 PM
euro911sc's Avatar
The washer does block the holes. This is to keep the pin in the hole of choice. I suspect, if you could rotate it 180 deg and it fit you had the luck of trying to get one of the tool's pins into the hole where the little timing pin resides... Obviously, if the pin is there the tool can not be there as well. 180 deg rotation gets you an open spot on the tool.
Just a guess.
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 04-11-2008, 06:37 PM
