Alusil Mahle Cylinders????
I have a set of 90 mm pistons and cylinders out of a 2.7, They definately are Mahle, but appear to be alusil???. The cylinder bores are not magnetic in any way, and they appear exactly like the KS alusil cylinders. I think that I had heard some time back that these are silical, which has similar properties to alusil. Anyone seen these before????
No left turn un stoned |
3 restos WIP = psycho
Rare, but they exist.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
maybe they were re-plated by another facility?
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Here's a side-by-side pic of a 90mm Alusil and Nikasil...Both Mahle with P/N 90ZN2W5.
Externally they appear identical with the only difference being in the inner bore of the cylinder.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
I got boxes full of the supposed rare Mahle Alusil cylinders, how many do you want? Oh, another way to see if they are Mahle LS Alusil cylinders is that the bottom of the piston skirt is cut straight across, the Nikasil piston has a little tab that sticks down below the skirt a bit. I can dig a picture up if you need it. That is if they are stock and nobody has messed with them on a prior rebuild.
Ray
76 911S Targa An ex F1 driver, and Porsche fanatic (my stepfather) once told me that if you listen very carefully on a quiet night you can actually HEAR Porsches rusting in the garage! Last edited by Ray_G; 04-13-2008 at 05:30 PM.. |
Rare doesn't mean desirable.
