Turbocharging A 911 SC
G'day Team...
I have a few questions regarding turbocharging a 911 SC:
1. Where is the best position for the turbocharger oil drain, back into the engine?
2. Is it necessary to have a scavenge pump to pump the oil back to the engine from the turbocharger, since the turbocharger is low compared to the height of the engine?
3. Has anyone modified (removed material from) the standard CIS pistons to reduce the compression ratio (for use as turbo pistons)?
4. What is the best position for knock sensor(s)?
Regards
Mike (just getting into this Porsche engine debacle)
Old 10-31-2006, 10:16 AM
Send a message via Yahoo to Lukesportsman
go to technical section (outside of engine building forum) and do a search. You'll find one very long and active threads along with many other. It will cover old installations to more modern theories with photos. Worth the time if even considering such an adventure.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 11-01-2006, 07:53 PM
WydRyd's Avatar
Re: Turbocharging A 911 SC
Originally posted by mbrown
G'day Team...
The aftermarket turbo crowd is gravity draining the oil back into the lowest point on the left chain housing/cover. Works fine with the turbo raised up slightly. The scavenge capacity of the engine oil pump will provide enough suction to keep recirculating the oil
Lots of posts/pics in the Tech Section... do a search for "gravity drain".
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-01-2006, 08:11 PM
Air Medal or two
afterburn 549's Avatar
Some have put a "banjoe" on the drain plug
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-01-2006, 08:49 PM
I have a huge thread on my project I will look for it and provide the link
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-02-2006, 05:47 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/291882-well-finally-started-install-morning-post2904230.html#post2904230
Here it is and bumped it for you
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 05:55 AM
crimson ghost's Avatar
Send a message via AIM to crimson ghost Send a message via MSN to crimson ghost
Great thread ! No more additions ???
1958 Karmann Ghia
Old 01-20-2009, 12:07 PM
Chain fence eating turbo
Mine drains into the drivers side cam cover and I have turbo, flat-top pistons.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-21-2009, 04:58 AM
