Has anyone done it yet?
Kicking ideas around for fun motors with friends the other night and we some DFA, DFV, DFX, gt3rsr and some other fun heads laying on a bench comparing them and were wondering......Has anyone ever removed the intake port runner from an air cooled 911 head? We were thinking if you could remove the runner, weld up the head a bit to provide material to bolt a very short throttle body onto and possibly even position an injector in there you could pick up some more performance with proper intake length and possibly resonance chamber tuning along with some dyno time and exhaust tweaking. We were just trying to figure out if anyone else has ever done something like this to position the throttle body closer to the valve.
74 911s neverending story. two feet and a jetta for now. |
Max Sluiter
MFI throttle butterflies were pretty darn close to the valve and the injector was right there to. If its in the chamber, the head looks like swiss cheese if you have 2 plugs, an injectore, bug valve (or 4 valves). MFI has the nice trumpets for high RPM ram air power too.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Its a decent system from a long time ago. The motor to be modified is running Jenvey itb's and bosch motorsport injectors. The mfi butterflies are pretty close to the valves but still not that close, plus we are thinking of a closed loop 12 injector setup with injectors down low in the heads and much higher up in the trumpets or above them depending on how short we can make them with a proper sized resonance chamber. I like the ram air power though lol.
I would rather be driving
Steve Weiner has some previous posts about installing a 3.6 intake on top of short ITBs for impressive gains. This should be relatively simple given the rubber coupling bushings to the injector blocks.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
That is basically what the RSR's ran. I am talking about machining the head ports and making them almost level with the fins leaving enough material to bolt something to.
So you want to take the intake port boss/flange right off? Interesting idea.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
