scarceller's Avatar
3.2L Intake Air CFM?
Hi,
I'm going to start a new project for replacing my AirFlowMeter (AFM) in my 3.2L Motronic Carrera with a Hot Wire Air Meter. Just starting to see what hot wire meters are available and I'm leaning toward trying something from the Ford Mustang family.
The question I have is does anyone know what the 3.2L air intake requirements are in CFM? At Idle and max CFM at WOT?
Or I may just use the available calculators that estimate the CFM based on Liter size of the engine. These calculators calculate about 350CFM for a 3.2L
The idea for the conversion is to simply replace the AFM with a Hot wire and a specialized WideBandO2 controller that will convert/map the 0-5volt signal from the Hot Wire meter so that it looks exactly like the AFM 0-5volt signal. I already have the WideBandO2 installed in the car and it has the ability to take a 0-5v input and map it to a 0-5v output. The maps are created/defined in the software via a laptop and then stored into the controller. This will allow you to keep the current chip and allow you to easily switch/swap between the AFM or the Hot Wire.
Thanks.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 06-04-2008, 05:29 AM
