-   -   Coil-On-Plug for Aircooled Engines? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/413272-coil-plug-aircooled-engines.html)
304065 06-06-2008 08:23 AM
Does anyone have experience with, or photos of, coil-on-plug setups for the 911-based aircooled engine?
I know the water-cooled cars use these, I wonder whether they are suitable for use next to the high temperature cylinder heads of a 911. Often times you see direct ignition with coil packs and short wires running to Beru-type connectors.
I have checked the websites of most of the shops and haven't seen anything for sale which is why I am curious.
Steve@Rennsport 06-06-2008 09:10 AM
Herr Professor Von Cramer,
We are working on custom valve covers for these cars to accomodate a C-O-P ignition setup.
We have done some of these using Motec Engine Management that works out just fine but the main issue is securing the ignition modules to the upper & lower valve covers properly.
304065 06-06-2008 02:20 PM
Dr. Ing. Steve,
I was hoping you would chime in. . . I think our man Peter Dawe has done something like this as well. . . hard to find photos out there.
It looks like the Boxster uses a Beru coil with a separate connector to the plug. I wonder what the distance from seated on the plug to the surface of the cover is. . . could one weld a couple studs to the aluminum cover to hold the coil? Hmmm. . . .
http://forums.pelicanparts.com/uploa...1212786148.jpg
I cannot seem to find a good picture of the 996 valve cover design. Tony (911quest) can you help, I know you tore a boxster engine down.
NY65912 06-06-2008 03:18 PM
Hi John,
When Bill and I were disussing my build he mentioned that he had done a few and if I were interested. He knew that I like a very clean uncluttered engine bay.
I said no.:D
Dennis Kalma 06-06-2008 03:29 PM
I am going to do it, I hate spark plug wires, distributors, advance curves, rotors, condensers and all that crap.
I was planning on just modifying the existing valve covers (drill out the holes, put in studs and go from there), but Dr. Steve's stuff may be interesting.
I also have to plug my distributor hole, I have seen Clewett's solution, don't like it all that much and was wondering if a press in aluminium disc with a couple of small retaining screws, all loctited and/or staked in, would look better and still be dry.
My only reservation is that Motec is expensive, but maybe they will make a stripper version for us street guys....
Dennis
Steve@Rennsport 06-06-2008 04:51 PM
Dennis
They do make a "cheap" version that is VERY good: M48, but it doesn't have sufficient outputs for C-O-P ignitions. One needs M600 to do this and that one is not cheap.
When it comes to Engine Management, you get just what you pay for,...:)
TimT 06-06-2008 05:09 PM
When I built the latest iteration of my motor a few year ago I was all set to do cop ignition, but my funds dried up... so I put a quick waste fire setup together.
I think the coils were almost $100 ea then.. I couldn't swing $1200 for coils then.
Bill and I were talking the other day, and we are going to do COP on his monsters powerplant... Also Dawe has a few out there running COP
kiato4 06-06-2008 05:31 PM
I believe Musante Motorsports and Rudtners are among the few who have attempted this with success. I have only good things to say about both of them, and I personally own a car that was converted to EFI by Bill Rudtner.
WERK I 06-08-2008 08:10 AM
I was going through the Jeg's catalog the other the other day, thinking the same thing. Maybe there are U.S. COP that are lower cost? I know the Ford DOHC engines have a pretty deep recess for the spark plugs similar to Porsches.
jcge 06-09-2008 03:57 PM
John - try this site for dimensions of the module - looks like type PT
Ignition coils at Bosch Motorsport
Regards
John
304065 06-09-2008 04:12 PM
That is a nice dimensioned drawing that I can use to see where the coil would sit on the valve cover-- thanks.
http://www.bosch-motorsport.de/pdf/components/ignition_coils/Single_PT.pdf
sourcandy 11-09-2009 07:21 PM
sorry to bump an old thread, but I currently have 6 beru coils wired up to a 3.2L motor that I'm trying to get running with Megasquirt. I was curious if anybody has made progress with modifying the valve covers? I was going to make a bracket, but the valve cover idea sounds like a cleaner solution.
Thanks,
-Ed
K24madness 11-10-2009 03:21 AM
While the coilover setup is desireable I find the Crane CDI unit to be the best solution when considering cost vs performance.
kenikh 11-10-2009 08:50 AM
there are several threads on this. some have used zx7 cops or audi cops effectively on 911 motors using an ems .
safe 11-10-2009 01:34 PM
I'm using the Audi/VW coil-on-plug. I drove at least 4000 miles this summer, both street and track, with coils from the scrapyard. No problems at al.
rsscotty 11-10-2009 05:47 PM
COP Valve cover
This is a new setup developed by Rothsport in Oregon. You can call Jeff Gamroth for details. 503 885 9626
http://forums.pelicanparts.com/uploa...1257903978.jpg
kenikh 11-10-2009 05:57 PM
Seems to me it would be cheaper to just fabricate an adapter ficture for existing valve covers that bolt to the existing fasteners. Billet = BIG BUCKS.
Jeff Alton 11-10-2009 09:01 PM
Billet does not need to equal big bucks for something as simple as a valve cover. With the right equipment valve covers can be made pretty inexpensively....
Cheers
lindy 911 11-11-2009 05:41 AM
I was just over at Pro Technik in Houston and they have a 3.2 based race motor that uses Motech EFI and Toyota Tundra COP. This is a single plug motor running 10.5 :1 compression making 325 RWHP! They just welded a stud to the valve cover and bolted the coil to it. Very clean! Call Sam and he'll share the details.
safe 11-11-2009 06:45 AM
I don't use any extra fasteners... Haven't fallen of yet.
http://forums.pelicanparts.com/uploa...1243546343.jpg
But the Rothsport solution is beautiful!
