I know, but the R-coils appears to be better. I carry a spare if one should break down. :) |
I might add that I got all my coils used from the scrapyard, I have used them all summer ~5000 miles mostly to/from track and on the track.
What I have read is that they fail more frequent in turbo engines with higher than stock boost. I think an air cooled 911 is a nice place for a c.o.p, dry and with a constant airflow. |
Does anyone know if the Toyota Tundra coils have built-in drivers? http://forums.pelicanparts.com/uploa...1262368333.jpg Is this what Pro-Technik uses? Any photos of these installed? Len :) |
Boxster GT,
The other thread on this subject has a description of a test that demonstrates that the 4-wire Toyota coil required 12v and ground and 5v and ground which in indicative of an internal driver. See post #97 at this URL. http://forums.pelicanparts.com/911-engine-rebuilding-forum/437273-using-coil-pack-ignition-5.html#post5100037 |
I have a set of six Toyota Kluger coils (= Highlander in US) #90919-02246, but these seem to be unique to this petrol V6 model in Aus, which is a bit inconvenient. http://forums.pelicanparts.com/uploa...1262397957.jpg They are good for length and seem to have internal driver (although not really sure what that is). I figure if the coil only needs a power supply and a signal, it must have an "internal driver" - correct? :confused: Still need six more, so other equivalent part numbers would be handy to know. I have also been trying to get a data sheet (like the Bosch details linked in an ealier post) but Toyota aren't interested in helping with that. Quote:
You have mis-read my post I think. The Toyota coil I tested on my bench worked with 12V for coil power and 12V signal, NOT 5V. Unfortunately, I haven't been able to confirm what the correct signal voltage should be, so I just crossed my fingers and used 12V and it worked without getting fried in the process. I "ran" one coil for a few minutes (stroking the signal wire along the file) continuously and it survived. The body of the coil warmed up a little as you might expect. |
COP wiring
Anyone got a contact for Toyota (Denso) wiring connectors?
http://forums.pelicanparts.com/uploa...1262400177.jpg I can get the plastic plugs from Toyota (90980-11885) but they don't come with the metal terminals or wire seals like this ... http://forums.pelicanparts.com/uploa...1262399772.jpg |
MoTeC USA sells the connectors. So does Ballenger Motorsports. I'm going to use them with a MoTeC M800 on my dual-plugged 3.3SS.
Ok, I found this item today while searching for ignition coil info. It is a coil targeted for ford applications but is built like the Kawasaki coil. Should be easy to get info for its operating requirements since it replaces the oem COP on many ford and Mazda applications. Its completely redesigned and cost is from $60 each. I like this design because you can just use a tab on the bottom like the twin plug wire holder tabs to hold them in place. No need to fabricate a mount or bracket.
Main webpage: WeaponX Performance : High Performance Automotive Products Application cross reference: http://www.weaponxperformance.com/technicalPDF/WeaponX%20Ignition%20Coil%20Interchange.pdf http://www.weaponxperformance.com/IgnitionCoilsS2.jpg |
This looks good Bill, and its half the price of a new Toyota coil. Have you bought one to test yet? Len :) |
Is it a general rule of thumb that the 2 pin coils require seperate drivers, while the 4 pin coils have built-in drivers? I thought the Kawasaki coils were 4 pin, same as the Toyota coils; but now I see they are 2 pin and can be triggered by an Electromotive Crank fire HPV-1(??) Len :) |
The Kawasaki coils doesn't have a driver, I think that's why it needs 88volt input (they can make the coil smaller) kind of like the Porsche CDI pumping out 400v to the coil. |
I thought as posted previously, the Kawasaki coils work on the 12v signal from the Electromotive HPV-1?? How about the 2 pin Ford coils shown above? What voltage drives them? Len :) |
heres a pic of c o p engine from peter dawe's shop.Sweeeeettthttp://forums.pelicanparts.com/uploa...1265130654.jpg
Interesting thread... I will have to peruse the others to learn more. I assume it would cost >1$ to add this to an existing engine or build. What is/are the benefit(s)?
Looks like Jenvey throttles with the carbon intake made for Rothsport by a fellow Pelican......
Cheers |
Anyone have experience with AEM? AEM CDI Box AEM COP Andrew, I think $1600 is cheaper than the cost of a M600. Just an option... Bill |
Wow, that makes for a cheap CDI wasted spark twin plug solution too. OTOH, LS-1's have built-in ignitors so they are easy to drive from any ECU and can be had for almost pennies. The D585 LS-2 coils (truck coils) are the real brutes. I have acquired 16 of those off ebay for less than $400 (most of them brand new) and they also have built in ignitors. It's CNP, not COP or CDI but it is cheaper high energy spark.
thanks for the info provided....
If someone is looking for the vw coil connecor this is the cheapest route I have found. I payed $45.00 for the harness with four connectors used what I needed and threw the rest away.http://forums.pelicanparts.com/uploa...1265562585.jpg
http://forums.pelicanparts.com/uploa...1265562657.jpg |
P.S- had the audi coils for a great price and returned them due to the price of the connectors... |
| All times are GMT -8. The time now is 07:05 AM. |
