77 2.7 issue
Hi guys, I have a sick 77 2.7 at my place.
Customer/friend brought it in to me, hasn't run in 11 years. Flushed the gas tank and dug into some wiring issues. There was an original issue of no spark, but I noticed that Someone had the coil hard wired as well as the WUR. After giving power to the hot side of the coil, I can get the car to run (barely). I ran it very breifly to get some EGT from the cylinders to see if I have a misfire. I have temps in the 160 range on the 1-3 bank and no temp on the 4-6 bank. Jumped cam timing?
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R... |
Fuel distributor is jumping out at me. Bad/old varnished fuel gets everywhere, not just the tank.
No physical quantity completely explains its own existence |
Ok, I'll pull injectors to see what's coming out. but this was on ether..... so I would have expected a little temp on all
Think I'd be doing a compression/leakdown test before inflicting ether on the poor thing.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
I appreciate all the help.
Check the cam timing, that's where a novice would get lost.
Everything else is just torque specs... Bruce |
"definitely not"... poor car.
I am bring this thread back up....
Engine is coming out today to check cam timing and do an over all check of things... It doesnt look good. One question I do have is do they make a replacement plastic connector for the main wire harness coming off of the chassis? The one in the car was in pieces.
Puny Bird
Never use ether on a 911 engine, you may as well try to start it by using a sledgehammer on a piston to spin the crank.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Beating a dead horse, leakdown is 80-90% on 4-5-6
