Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by ajwans View Post
How do you attach that spacer to the idler arm? Is it a big bushing turned down on the idler
end and pressed into the arm?
andy
Sorry for the delay in responding. The idler arm is machined out to accept the new bushing.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-26-2009, 09:48 AM
abit off center
cgarr's Avatar
Henry, Have you ever tried an internal collapse stop inside that tensioner rather than the collars?
______________________
Craig
G2Performance
Old 01-26-2009, 10:41 AM
No, but the idea sounds good.
My only concern would be: Why would I want to disassemble a new tensioner to install a stop when a collar can be added without disassembly?
Henry Schmidt
Ph: 760-728-3062
Old 01-26-2009, 10:54 AM
Tags
idler arm update , turbo tensioners
