what "TIMESERT" measurement for 7R mag crancase?
what "TIMESERT" measurement for 7R mag crancase? for head stud,,,
Old 06-28-2008, 01:03 AM
sww914's Avatar
Do you mean what is the thread size and depth?
Old 06-29-2008, 10:08 PM
size
Old 06-30-2008, 12:35 AM
Irrationally exuberant
ChrisBennet's Avatar
TimeSerts are better than Helicoils but I believe there are better inserts for this application i.e Case Savers. A TimeSert will works by expanding into the metal and there isn't much metal between the insert and the cylinder spigot. This a job best done by a machine shop/milling machine. I worked on a 2.7 once that had been TimeSerted by hand at some point - the studs went every which way. I think the term for this sort of case is "porcupine".
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-30-2008, 05:30 PM
abit off center
cgarr's Avatar
We only use case savers in our mag cases, they are 14x2 and if you set it up to favor away from the spigot just a tad you can still leave a good amount of cylinder surface. PP sells the timecerts, give them a call and have them size one for you. but try to stay with at least a 2mm pitch for good bite into the mag case.
______________________
Craig
G2Performance
Old 06-30-2008, 05:52 PM
