kandhmfg's Avatar
Distributor Question 2.7L Rebuild
After case failure on a 2.2L bored for 2.7L cylinders, I am rebuilding my 2.7L motor using a later 7R case from a '76 car. I just noticed the distributor I was running will not work. Where the distributor fastens to the case for timing adjustment is taller in nature than the old case was. It actually extends up, versus just being a stud next to the distributor port.
The engine has 90mm RS P/C's 8.5:1 (but true compression may be higher because it still has 2.2L heads), heads are ported to 36mm intake, stock exhaust ports, mod S-cams, running 40mm webers, it was a screamer before.
What type of distributor should I be looking for? If I run the standard distributor for the 2.7L without the vacuum advance will that be okay?
Any thoughts, suggestions are welcome.
Thanks,
Erik
Old 07-05-2008, 03:42 PM
Try not, Do or Do not
Henry Schmidt's Avatar
You can add vacuum ports to your manifolds and use a stock 2.4/2.7 distributor or have a stock 2.7 converted to mechanical (only) and recurved for your application.
Do a search and you'll find shops that can do this service.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-05-2008, 06:33 PM
jaybird840's Avatar
Send a message via Skype™ to jaybird840
Sorry for the hijack... Henry, I'm building the same engine as this guy... RS spec 2.7 with 40 Webers. Can I run the stock curve designed for CIS with my webers if I install a vacuum port in the manifolds, or does the dizzy need to be recurved for the carbs regardless? thanks!!!
Jaybird
'75 914--slowly becoming a supercar
2.7RS spec rebuild in progress
Old 07-15-2008, 05:55 AM
As long as cams and compression remain the same there is no need to recurve the distributor.
Since the cams are being upgraded to "S" spec I would highly recommend a recurve.
You might also search for a 73"S" distributor. The curve on the dist. will closely match the curve you need, if you are willing to run a vacuum advance.
Henry Schmidt
Ph: 760-728-3062
Old 07-15-2008, 07:15 AM
jaybird840's Avatar
I'm actually going to run Stock "E" cams...so I guess a recurve is in order. Also, you bring up an interesting point I've been meaning to ask about C/R. When CGarr rebuilt my heads, he skimmed .010" to clean up the sealing surfaces. Approximately how much of a bump in C/R should that produce, if everything else remains the same? Thanks for the input....
Jaybird
Old 07-15-2008, 11:00 AM
abit off center
cgarr's Avatar
Jay, The heads were marked -10 or .10mm or almost .004 thou,
______________________
Craig
G2Performance
Old 07-15-2008, 11:22 AM
jaybird840's Avatar
see what happens when you "assume"!! Thanks, Craig! (so, what do you think that will do to my c/r?)
Jaybird
Old 07-15-2008, 11:27 AM
