Question Please Help !!! (cam Timing Values)
Hello to all,
I have the LH cam towe opened I have also remove the tensioner and undo the big nut.I leave engine to work on it later.When I came back my little brother has done his "trick" he remove the cam nut - cam pin and ofcourse cam nut ! Take notes ?? What notes
Does anyone have the cam timing values handy ?
Engine #66603xx 1976 3.0 Carrera (930/02).
A BIG thank you to all and wishes to have a nice weekend
Jim
Jim Wolf
"WHEN WE START RUNNING YOU BETTER CATCH UP"
Old 07-12-2008, 11:40 AM
I found the following values :
0.9 to 1.1 mm (0.035” to 0.043”) for the 1976 and 1977 3.0 liter Carrera
Can someone confirm if they are the correct ones
T H A N K S
Jim
Jim Wolf
Old 07-12-2008, 01:27 PM
Irrationally exuberant
ChrisBennet's Avatar
Those numbers are correct according to Bruce's book. That cam profile was used for the C3, SC and Carrera so you could set it to anything between .9 and 1.7mm (though it wouldn't make much difference.)
The spec alone is insufficient for setting the timing on the left - you need to make the left and right match. It's more important to make the left match the right than the actual value.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-12-2008, 01:45 PM
Thanks Chris,
I also need the valve gap right ?
Jim
Jim Wolf
Old 07-12-2008, 01:56 PM
Hi Jim,
From the factory manual, intake valve opens 1.0 mm @ 1 degree before top dead center.
Setting should be 0.9 to 1.1 mm @ TDC.
Your info is correct.
It should be noted this is the same cam and cam timing as the '78 and '79 SC's.
The SC's changed the same cam to 7 degrees before TDC in '80. 1.4mm to 1.7mm.
The '84 Carrera's with the same cam split the difference and went for 4 degrees BTDC.
1.1mm to 1.4mm.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-12-2008, 02:03 PM
Mark S
Yep what Chris said just check the right and set left. Yes you need valve clearance checked/set before you measure to make sure it's correct on right side also set left side before you time it. If right side is not the consensus .9-1.1mm holler back.
Old 07-12-2008, 07:40 PM
