sudo apt-get purge 930
equality72521's Avatar
Question about oil in a empty engine
I just got done replacing all of the seals, o-rings, gaskets, blah blah blah in my engine let were leaking. I put in Carrera tensioners and a new turbo as well. The engine is completely empty of oil right now as I just put it back in the car. My question is how do you prime everything before starting the car? I have no oil in the pump, turbo, any of the new oil lines. I don't want to just start it like that. What do you guys do?
--clutch-monkey
Old 07-13-2008, 02:56 PM
abit off center
cgarr's Avatar
Can you cut off the fuel and spark and crank it till you get oil pressure? When I assemble I always try to prime areas as it goes together.
______________________
Craig
G2Performance
Old 07-13-2008, 03:02 PM
Yeah, I could do that. Is that going to be fine? How long do you think it should take to build pressure?
--clutch-monkey
Old 07-13-2008, 07:23 PM
abit off center
cgarr's Avatar
I didn't read your post right, I thought you rebuilt your engine, you never cracked it open? that means there is still oil in it, you should have pressure rather quick, I would just give it a few 5 sec cranks and I bet the lite goes out. It would be no different than me pulling mine out of storage after a year I would guess.
Craig
G2Performance
Old 07-13-2008, 07:37 PM
No, I never cracked the case. It is drained to the point of no matter which way the engine was in the stand there was no oil coming out.
--clutch-monkey
Old 07-13-2008, 07:42 PM
dtw dtw is offline
GAFB
Just kill your ignition and spin it a wihle on the starter. You can spin it (in 10 second intervals with rests in between for your starter) until the oil pressure light goes out and/or you see your pressure gauge start to twitch. Just did a new engine and only took 20-30 seconds total.
Several BMWs
Old 07-14-2008, 02:29 AM
Great. Thanks guys.
--clutch-monkey
Old 07-14-2008, 03:34 AM
Remove spark plugs so the engine can spin faster/starter has less resistance to rotate. Not sure oil pressure threshold will be high enough to register on the gauge, but you could temporarily loosen a convenient pressure line and watch for oil (e.g. oil fed chain tensioner) to confirm.
Sherwood
Old 07-14-2008, 04:08 AM
resident samsquamch
sand_man's Avatar
That's how I do it, as well...
-jeff
Old 07-14-2008, 10:40 AM
That worked perfect. Thanks a lot everyone.
--clutch-monkey
Old 07-15-2008, 05:29 PM
peppy's Avatar
Will this put fuel into the cylinders?
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 07-15-2008, 05:56 PM
I pulled the fuel pump relays to prevent that.
--clutch-monkey
Old 07-15-2008, 06:07 PM
resident samsquamch
sand_man's Avatar
With CIS (as in a "stock" 930), the injectors release fuel when the metering plate is depressed. However, the fuel pumps can be rendered inoperable by either disconnecting the wire on the overboost sensor, or pulling the two fuel pump relays closest to the windshield on the luggage compartment panel, or by pulling the overboost relay on the engine compartment fuse panel.
-jeff
peppy's Avatar
Thanks!!
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 07-15-2008, 06:17 PM
DSPTurtle's Avatar
Sandman, if that is true you are a genius!!! I do know I have shorted the overboost sensor to ground in teh past to make sure that was not the problem, but can I really not even have to pop open the fuse box to crank the motor to build oil pressure?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-17-2008, 04:10 PM
resident samsquamch
sand_man's Avatar
If all your wiring is still "stock" (not tampered with or "re-wired" by a previous owner), then yes, disconnecting the wire to the overboost sensor will kill the fuel pumps.
-jeff
Old 07-17-2008, 06:35 PM
DSPTurtle's Avatar
Damn the disclaimer. I am not sure how stock all that wiring is since I tried to remove most of the aftermarket stuff they put in there but I certainly did not get it all. Oh well, time to pop the boot and pull the relays.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-18-2008, 06:20 AM
