Which head studs to use?
I am rebuilding a 2.0L (aluminum case) to a 2.5 SS. Could I use the original head studs, if not, what type should I use?
Sigmund 964 -92 911 -76 912 -67 |
There are numerous threads on this. My opinion is to use the original steel studs with that combination.
-Andy
72 Carrera RS replica, Spec 911 racer |
Use your stock steel ones with confidence,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Your post suggests (short stroke) 90mm cylinders.
If so, Dilavar.....the coated, full thread jobbies. On the other hand, I never disagree with the good Mr. Weiner & I'll probably get a quick education.
JPIII Early Boxster |
Thank's for the replays, I have full confidence in Steve, so I use the original ones....
