extra part - whats this for?
So there is an extra seal in my kit. Looks like the seal that goes behind the cam covers but I am positive I installed two. Did I miss somthing?
Thanks, Chris 73 911 E
The only other O ring that looks like that is the #8 nose bearing O ring. If I were a nicer guy I'd dig one out and measure it, but I'm not.
I definitly have the#8 bearing gasket on there and this is bigger. Thank god it is not somthing that should be in the case. I think my gasket set came with an extra cam cover gasket.
Could be complete tomorrow
The seal kit covers a lot of engines, for some the is quite a few seals left over...
If your confident that you haven't forgotten something, trust your gut.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Uncertifiable!!!
930 intercooler intake seal.
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Thats great news. Its almost ogether, the end is in sight. Would not be happy if I had to take it down to the case again. Its been a longer then expected project with a few set backs along the way.
I dropped one of the cylinders and it cracked $500 mistake One of the pistons ring lands was broken $1000 for new ones Machine shop installed the case savers 2 mm shallow so spent $200 on 996 head bolts which are slightly longer Dont see any more set backs on the horizon and the hard parts are done :-) Chris 73911 E |
Goes under the throttle body if its the same as the seal behind the cam gear.
Bruce |
Looks nice... shiny
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
almost done. last part arrives today...engine / trans stud.
Chris 73911 E |
Free minder
This looks like a camshaft plate o-ring. I also got an extra one in my seal kit.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Nice picture man ! good luck
