Which PMOs !!!
I have a -79 SC engine large ports, SS 3.2 syl, JE 9.8 pistons. 964 cams, ssi ex. blue printed, and would like to have a pair of PMOs on this engine.
The car is mostly driven on common roads. Should I go for 40s or 46s ?? |
46's would be appropriate w/38mm venturis.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Will this give some more HP ??
Thank you Steve !!!!
My race group has found about a 7HP peak improvement with 46mm carbs vs 40mm carbs. This only occurs above about 6000 RPM.
-Andy
72 Carrera RS replica, Spec 911 racer Last edited by Eagledriver; 08-10-2008 at 08:56 PM.. Reason: changed 60 to 40 |
