Soda Blasting
Fellow Pelicanites
Is it OK to hit the mating surfaces (i.e. head/cylinder, cylinder/case, case/case) while cleaning (i.e. carbon/oil stains, old sealing compound) with soda at 100psi? Will it damage the sealing surface? 1990 3.6L TIA Bill 90C2 |
Hi Bill,
I am running my soda blast pod at 120psi and I have noticed no problems with the mating surfaces. The soda is very good for such conditions. That being said, it would be interesting to hear some additional thoughts (since I have only had my blast pod for 3 months) Regards,
Dan Criss ================== 1980 911sc wide body |
Use that stuff at 100-120 psi with no worries,.. ![]() Thats the very best way to clean aluminum engine parts.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
So the dullness I see after I hit a shiny aluminum surface is not pitting the surface? 1st time 911 rebuild TIA Bill 90C2 |
