whackit's Avatar
location of intermediate shaft size stamp on case
hi all.
I'm trying to figure the sizing on my case for a new shaft but i can't find the case stamp.
the factory manual says "beneath the alternator mount on left side of case".
Can anyone be more specific or show a picture please?
thanks.
1971 911E 2.7RS interpretation -- Signal Orange baby!
Old 08-17-2008, 08:12 PM
MBEngineering's Avatar
HI whackit
the code is hear on the case
you could have a "0" or a "1" stamped there as to what was fitted from new.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 08-18-2008, 02:03 AM
whackit's Avatar
hmmm. nothing on my case.
Old 08-18-2008, 08:11 AM
abit off center
cgarr's Avatar
Do you have the pulley off? Mine is under the the pulley but in the same area.
______________________
Craig
G2Performance
Old 08-18-2008, 08:26 AM
304065's Avatar
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-18-2008, 08:54 AM
whackit's Avatar
Here's the only marking I found in the area described. Would you consider that a 1?
Old 08-18-2008, 03:51 PM
whackit's Avatar
anyone?
Old 08-20-2008, 09:46 AM
abit off center
cgarr's Avatar
Thats not a 1, looks like you are going to have to check it when its apart.
Craig
G2Performance
Old 08-20-2008, 09:56 AM
When I needed a new gear on my intermediate shaft I found that only one size was available. It's been a couple of years but it seemed to me that unless you have 1's on both the crank gear and the case you can use a Zero gear. The rule is specified in the factory manual.
-Andy
Old 08-21-2008, 08:16 PM
whackit's Avatar
actually if you do have 1's on both the crank and case then you CAN use a 0 gear. Here's the table:
Old 08-22-2008, 09:18 AM
