Expandable Oil Return Tubes
I'm going to replace my Expandable Oil Return Tubes and I'm not sure which ones to buy. Wayne has two types: Bespoke Aluminum and OEM steel type, any suggestions?
Also, as an act of preventive maintenance should I replace my exhaust head studs with Waynes new non-corrosive shiny ones? Or leave well enough alone.
Engine is in car.
Thanks!
Old 09-13-2008, 02:10 PM
OEM steel oil return tubes are not expandable. I don't think there is an OEM expandable tube. I think any of the expandable types work fine if you are careful on the instalation.
I wouldn't touch my exhaust studs until I needed to remove my heat exhangers. Even then I'd probably leave them alone. If you find some that are corroded when you remove the exchangers then maybe replace them. If you break one you'll be very unhappy with yourself.
-Andy
Old 09-13-2008, 03:21 PM
3.2 CAB's Avatar
OEM one piece steel....901-107-351-01-M260
OEM 2 piece steel........930-107-040-01-M59
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-14-2008, 04:27 PM
haycait911's Avatar
I like the aluminum ones. sometimes it takes a bit of pushing/pulling to get them seated using clamps,etc. and the aluminum are much stronger.
Old 09-16-2008, 10:43 PM
3.2 CAB's Avatar
As far as preference goes, I prefer to use the OEM expanding oil tubes, 930-107-040-01-M59 because the o-rings seem to be easier to locate, being they are a genuine Porsche part, instead of being an after market offering. Tony.
Newest additions-
others...
Old 09-17-2008, 08:46 AM
I'm here to cause trouble
jimbauman's Avatar
I put in the Weltmeister expandable aluminum tubes several years and numerous track days ago - no drips, no runs, no errors....
JB
Old 09-18-2008, 06:18 PM
