E cam numbers
Are the the correct part numbers for an E cam set?
901 105 110 0R 901 105 181 0R Thanks! Speedo |
Those are the correct casting numbers for MFI E cams but if you want to be safe I would send them out and have the profiles checked. The 110 casting number was also used on early Solex engines with a different grind.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
