SigmundF's Avatar
Flywheel bolts
I am taking my 2.0 l -67 engine apart and when I came to the flywheel I was expecting some special bolts with a 12 point star head, but in my engine there was regular bolts (14 mm). Was this standard on the 67 model engines or is this the result of an previous rebuild?
Anyway does anyone have any suggestions to how I can get these bolts out? I can not get a regular socket on the bolts, they are to close to center... I apologize for the pore quality of the picture, it was taken with my cell phone
Sigmund
964 -92
911 -76
912 -67
Old 09-01-2008, 01:26 AM
These are not the correct type of flywheel bolt for the early engines.
They use the same 12 point bolt head as the later engines.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 09-01-2008, 04:49 AM
SigmundF's Avatar
That was what I thought too. Any idea how I can get them off
Sigmund
964 -92
911 -76
912 -67
Old 09-01-2008, 06:28 AM
al lkosmal's Avatar
I believe that there are thin wall sockets available from some of the tool manufacturers, like Stanley and Mac, etc..... Alternatively you can turn one of your sockets down or if you have welding capability, weld a nut on the end of the bolts and use it to remove them. Also use a propane torch or equivalent to heat the bolts, prior to removing. Heat is your friend and will help you get them out of there.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 09-01-2008, 08:01 AM
al lkosmal's Avatar
thin wall sockets
here's an ad for thin wall sockets:
RGruppe #669
Old 09-01-2008, 08:08 AM
304065's Avatar
Here is what it should look like.
Verify there is a thick washer under the heads. Can't tell from the Nokia!
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-01-2008, 05:28 PM
