Cylinder Base Gaskets
OK, just checked with Walt and found out they did cut my heads down .25 so I need to add another .25 cylinder base gasket. Can I reuse the old ones with the new set to make the .5 mm? I plan on checking the deck height using Walt's method listed in Wayne's book to see if it's in spec. If the deck height is in spec am I okay to proceed?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 09-02-2008, 03:10 PM
fastfredracing's Avatar
Would not re-use the old ones, either stack two new ones, or better yet, Andial has different thickness base gaskets available, I think I may have gotten these from EBS before.
No left turn un stoned
Old 09-02-2008, 06:06 PM
