Smile 3.6, 3.7, 3.8 What recipe do I have?
I bought this "trade in" engine and am wondering what my final displacement is? Redline?
78 SC Case Sprigots bored 4mm
964 crank
Mahle 102mm pistons and cyl
3.2 rods narrowed at top to fit pistons (22mm If I remeber corectly)
heads twin plugged and massaged as well as D ported
Turbo Pump
TWM 3003s 48mm
Tech engine management
I am looking for definitive answers so please no guesses.
Thanks for the help,
Rick
P.S. Hoping to get the car down to 1800#s
67 Normale "Old Rusty"
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 09-06-2008, 07:42 PM
BURN-BROS's Avatar
It's a bit hard to give a definitive answer when you do not give a complete build list.
You have a 3.8.
Cams? rod bolts? Without knowing those you are at the stock redline for a 3.6.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 09-07-2008, 09:59 AM
304065's Avatar
Well lemee see here definitive answers huh?
A 964 crank has a stroke of 76.4mm
Your pistons are 102mm
102 x 102 x 76.4 x 3.1416 / 4 * 6 = 3745cc lets call it a 3,8 same specs as the M64/20
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-07-2008, 10:55 AM
Thanks for the help guys! Does this fall under short or long stroke? I usually run 2.8s and smaller so this is uncharted waters for me.
I have ARP rod bolts and need head studs, ARP or Raceware. I recently saw on a thread that Henry Schmidt had his own? Are they his own creation or is he a dist?
I have factory 73 S cams and 3 support towers but think maybe Woods GE100 or 80s may be better suited. Are Jerry's 4 bearing? I have solid tensioners.
A local builder chromes the journals on his early 74 cranks and swears by it. He also builds some crazy mod 4 cyl 356 stuff. Any advice on chroming my 964 crank?
There seems to be some discussion on the turbo pump compared to the GT3 pump. My case has already been modified for the turbo pump.
Thanks again for the help.
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 09-08-2008, 04:15 AM
BURN-BROS's Avatar
I will not ever use a chromed crank period. It is also the longest stroke and crapiest rod angles that Porsche has made. But 6500-6700 rpm should be fine for that build
Henry's head stud are his own design and based off of 935 factory studs as far as material goes. I believe it is the best product on the market in regards to head studs.
Burnham Performance
Old 09-08-2008, 09:12 AM
3 restos WIP = psycho
kenikh's Avatar
I'd love to know what the coeeficient of linear expansion is on Henry's studs.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-08-2008, 09:40 AM
3.2 rods on a 964/993 crank???
Anyone know whats up with that?
Do the big ends fit?
Would the rod not be to long or is the attachment moved up on the pistons for a better angle?
I would think one would just use the stock 964/993 rods.
Thx.
Old 09-09-2008, 07:18 AM
Bill Verburg's Avatar
Thx.
3.2, 3.3 and 964 3.6/3.8 all use the same size rods interchangebly
993 3.6/3.8 use a different rod which is narrower and not interchangeable w/ the others
Bill Verburg
Old 09-09-2008, 07:37 AM
BURN-BROS's Avatar
I have not checked but it would be close to steel expansion rates if I were to guess.
Burnham Performance
Old 09-09-2008, 10:59 AM
If Henry recommends them then that's good enough for me.
The 3.2 rods I have, have been narrowed at the small end to fit the pistons.
Anyone used Smart Racing's rod bearings?
67 Rennen inspired
73 ST Caged Beast
RGruppe #383
Old 09-09-2008, 11:06 AM
