Project Addicted
Camshaft wear pictures
Hi all, we are getting ready to build a 3.4 from an '87 3.2 with 100K miles that needs a full on valve job due to bad guides with excessive oil consumption. We have purchased various parts from fellow PP members and I have some questions about some wear spots on the cams.
They are Webcam 20/21 grind, used with about 17K miles on them. There are some different wear spots on the backside of some lobes that I would like some input on. I can assume that the valves might have been adjusted too tight to leave these marks but I don't like guessing..... Your thoughts??
Thanks for taking a look. I appreciate your input.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 01-07-2014, 10:36 AM
When the rocker runs too tight, the polish runs all the way around the cam and produces some on the most radical burned and split valves.
Regardless, the defects are on the back side and have no effect on lift or longevity.
Remember these are cast iron
Bruce
Old 01-07-2014, 11:09 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Those cam lobes look like they have remnants of the dry film lubricant on that WebCam applies to all of their camshafts? Doesn't look like actual damage to me.
Kevin L
'86 Carrera "Larry"
Old 01-07-2014, 11:51 AM
Yeah ... Def looks like Dry Film that is wear away exposing the polished cam lobe under neath.
Old 01-07-2014, 12:20 PM
Project Addicted
Why the wear marks then. If clearance is set right why the polished spot in pic 2? I accept that it's dry fil gone but is this evidence that the rocker was bouncing or something else. It's odd right?
Jon
1966 912
1986 944
Old 01-07-2014, 04:22 PM
Navin Johnson
TimT's Avatar
Just observations..
Pic 1 and Pic 2.... nothing to do with wear from the rocker...
Smudges in the DFL from assembly/dis-assembly handling packaging.....
Pic 3
Note sure what you are concerned about in the circle you highlighted..
Pic 4
See Pic 3...
Again where some of the packing material got jiggly with the cam
'69 911 GT-5
'75 914 GT-3
and others
Old 01-07-2014, 06:22 PM
If you spray them with brake clean the remaining grey coating will wipe off. Then install with creamy assembly lube that stays in place. Or motor oil if the motor will be started again soon.
Old 01-07-2014, 08:27 PM
Project Addicted
Thanks guys (and/or gals) for the input. Will lube well before installed.
Jon
1966 912
1986 944
Old 01-08-2014, 09:09 AM
Straight shooter
Lapkritis's Avatar
Feeler gauge rubbing the film off when setting lift perhaps. Unless there's galling then nothing to worry about in my opinion.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 01-08-2014, 09:13 AM
