correct measurement for 2.7 rod journals
I have a 2006 wayne book, and it shows the rod journals as 56.971-56.990
I have 2 cranks with matching numbers and much smaller journals. is the book in error? what is the correct standard rod journal for a 2.4 - 2.7 (70.4mm) crank? thanks in advance brant
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
New Max diam - 51.990 mm
New Min diam - 51.971 mm wear limit - 51.960 mm 1st undersize is 0.25 mm less than these numbers.
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
thank you Tom
now mine look much better I'll correct my copy of the wayne manual brant
