Manassas, VA
lucittm's Avatar
Which Engine Tin Bolts?
In preparation for reassembly of my 1991 turbo engine, I noticed that there are two different types of OEM 6 x 12mm engine tin bolts with included washers:
1. One set of bolts is head stamped KAMAX.
2. One set of bolts that is head stamped BOESNER and seems to have the threads squeezed into a triangular pattern in order to provide a retention mechanism.
My question is - which bolts go where? I would think one type for use in aluminum in the engine and one for steel in the tins.
I think the replacement bolts sold by Pelican do not have the OEM head stamp, but if they are different specifications, there should be different part numbers. I just can't tell which is which.
Does anyone have the P/N's for each type?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 09-24-2008, 08:30 AM
304065's Avatar
The BOESNER headmark is a patented triple locking screw. Part number is
999 143 004 08
Pelican sells them for $2.25 each. That is the price of the patent.
Download the legal version of PET and look at illustration 105-07, you will see which are locking and which are conventional 999 075 039 02. These probably are the ones with the headmark KAMAX. I would show you this except PET cannot be copied. Anyway you want the page with the engine tin on it.
Good luck!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-24-2008, 08:47 AM
Manassas, VA
lucittm's Avatar
Mystery solved! I found the illustrations on PET pages 105-07 and 105-12.
I could not have done it without your reference to the part numbers, nice work.
Thanks,
Mark
Old 09-24-2008, 09:53 AM
911 tweaks's Avatar
Hi John... a few q's on this subject if you can help out here:
1. p/n 999 143 004 08 this is the BOESNER fastener... how many needed for an sc's tin ??
2. p/n 999 075 039 02 pelican says this is a m6x12 fastener... 16 req'd... is this a std m6x12 bolt w/ hex head ?? Also, does this 'bolt' need any washers ie flat and or lock ??
3. is it possible you can post pics of those 2 pet pgs or some how explain where these 2 fasteners are used ??
Thanks again for your always sharp & complete help to pelicans !!! :-)
Bob
I live for 911 tweaks...
Old 09-25-2008, 05:24 AM
