Eye of the Toiger
matty74's Avatar
Weber re-build
Hi
I Have an old set of webers from that I want rebuilt for a 3.0
Can some one tell me the following I need to suit a 3.0 SC motor
1. Venturi size - I'm guessing 34-36mm
2. idle jet size
3. air correction jet size
4. Emulsion tube size
Who would sell set shafts and floats for the weber carbs?
What else do I need??
Cheers
matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 09-21-2008, 05:32 AM
Check out Links 1 for info on jet sizes and this place has the parts...
http://youroil.net/weber_carb_parts.html
Our host likely has parts too.
Old 09-21-2008, 06:17 AM
Originally Posted by matty74 View Post
Hi
2. idle jet size
Cheers
matt
Hi Matt,
The answers to your questions really depend on the engine's configuration: cams, compression ratio. exhaust system, usage, as well as environmentals.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-21-2008, 06:10 PM
Eye of the Toiger
matty74's Avatar
At the moment stock 78 3.0 SC with ssi's and 2in 2 out exhaust, street and track.
Later I will put in some JEs and GE60 cams.
Steve - does your company rebuild webers? I need some one to rebuild them.
cheers
Matt
Old 09-22-2008, 01:46 AM
